After having the suspension strut bearing replaced the ABS light turned on?
DAVEDEAN
  • 2010 RENAULT SCENIC
  • 1.6L
  • 4 CYL
  • MANUAL
  • 110,000 MILES
My ABS warning turned on, on the dashboard after I had a driver's side suspension strut bearing replacement done. The mechanic told me the ABS sensor came away from the seating due to erosion of the metal around the seating and he replaced it the best he could.
What parts will I need to buy to make good the sensor?
Many thanks for your help, Dave
Saturday, November 26th, 2022 AT 9:04 AM
  • 108,489 POSTS
This vehicle isn't offered in the US, so I have very little info specific to it. However, I will try my best to help.
If you had the strut bearing plates replaced, the strut was removed. When this is done, I have a feeling the ABS sensor was either damaged or left disconnected.
If you check behind the wheels, you should find a wire going to the hub bearing (wheel bearing) check to see if it is connected or damaged.
I attached a pic below that shows, in general, where you can expect to see the wheel speed sensor.
Let me know if this helps or if you have questions.
See pic below.
Saturday, November 26th, 2022 AT 10:04 PM
DAVEDEAN
Many thanks for your help. Regards, Dave
Sunday, November 27th, 2022 AT 5:42 AM
  • 108,489 POSTS
No problem whatsoever. Let me know what you find or if I can help in any way.
Sunday, November 27th, 2022 AT 7:39 PM
