Sounds like the shifter position switch isn't adjusted just right. Just loosen the bolt slightly Put the truck in reverse and rotate the switch until it stops. Now put it into reverse with blocked wheels and slowly move the switch until you see the lights come on. Make a mark on the switch showing where you stopped, now rotate a bit more until they go off. Mark. Now rotate the switch to be between those two marks. Test the shifter and be sure it is correct.
Image (Click to make bigger)
Wednesday, May 22nd, 2024 AT 7:43 PM
