Shaking
SHMATTHE
  • 2014 BMW 328XI
  • 2.0L
  • 4 CYL
  • 4WD
  • 130,000 MILES
Car shakes when you start it, and when you drive it.
Wednesday, March 10th, 2021 AT 8:18 AM
  • 108,489 POSTS
A shaking can be the result of a few things. For example, an engine misfire, a vacuum leak, low or high fuel pressure, and so on.
Here is what I recommend. The vehicle's can-bus needs scanned to see if there are any modules that have codes. CAN stands for controller area network. This is how all the modules are tied together.
Here is a video showing how it's done:
https://youtu.be/InIlnsjOVFA
If you want, check to see if you can locate any vacuum leaks on the engine. Here is a link that shows how it is done:
If not leaks are found, have the computer scanned as I mentioned. Let me know what codes are found so I can better help.
Take care and God Bless,
Wednesday, March 10th, 2021 AT 6:23 PM
