Spark at coil but not at distributor cap
MAURICIO SOLORZANO
  • 2000 MAZDA MILLENIA
  • 3.5L
  • 6 CYL
  • 119,000 MILES
I own the vehicle listed above v6. I saw that you had the same problem as I did, and I received spark on the coil but not at the cap, even though the cap and the ignition rotor are new. What was the fix at the end?
Tuesday, April 5th, 2022 AT 3:42 PM
BORIS K
  • 766 POSTS
It sounds like you might have a faulty coil, coil is arcing to distributor housing when under load.
See video below.
https://youtu.be/OreZgv-VbA8
You can test the coil resistance using a voltmeter. Please see specifications in image 1 below.
How to use a voltmeter.
Please let us know how you get along.
Cheers, Boris
Wednesday, April 6th, 2022 AT 6:17 AM
