Squealing noise is heard when backing up?
RAPTUROS
  • 2007 TOYOTA CAMRY
  • 58,700 MILES
I notice that when I put the car in reverse and start backing up there is a fairly loud squeal coming from the rear of the car. I think it might happen when I apply the brakes as I am backing up. The brakes appear to work normally when going forward and stopping is decent although not a powerful grabbing of the brakes when I apply pressure to the brake pedal.
Tuesday, April 16th, 2024 AT 1:47 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Yep, this happens when the brake pads get too low and the warning "screamer" starts to touch the rotor which makes this noise, here is how to change the rear pads out in case you want to do the job yourself and save some money.
Here is a video to show you how as well:
https://youtu.be/-zHGYhjOxXo?si=X6qGcR4-3a79mPc_
Check out the images (below). Please upload videos in your response to the problem so we can see what's going on.
Tuesday, April 16th, 2024 AT 9:43 AM
RAPTUROS
  • 24 POSTS
Thank you much for the analysis. I will have the work of fixing up those rear brakes done by my local repair shop. I believe the correct way to help your site is by the way of the gofundme button so I will try that route (you used to have a PayPal button).
Tuesday, April 16th, 2024 AT 3:35 PM
KEN L
  • 43,468 POSTS
Yep, we will be adding that back. Here is the link to our gofundme:
https://gofund.me/c7d318ad
Thank you!
Wednesday, April 17th, 2024 AT 9:35 AM
