Replacing the start, how do separate rate the starter from the engine (it is stuck)?
ALZARB77
  • 2006 FORD TAURUS
  • 3.0L
  • 6 CYL
  • 126,000 MILES
The starter wouldn't work. Banged on it (old school). It worked but didn't the next time. I took all proper steps to remove it but it won't separate from the engine. Someone told me the Bendix gear might be stuck. Thought I might be able to manually rotate motor to maybe free it if it "is" stuck on the flywheel, but I don't quite see how I can do that. Camshaft pulley nut very difficult to get to.
Tuesday, August 15th, 2023 AT 5:40 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
I would hammer and contact the body of the starter, it is just stuck, it will come out. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car. Make sure you have all three mounting bolts out.
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Tuesday, August 15th, 2023 AT 11:25 AM
