Starting issue, my possible diagnosis is a bad fuel pump?
LINCOLNCARGUY99
  • 1999 LINCOLN TOWN CAR
  • 4.6L
  • V8
  • 125,603 MILES
I got off work, mind you I drove to work hours before. When I got in all the lights and automatic seat adjustments worked. But when I went to start the car, it didn't start. It turns over and cranks. Had someone called out there to attempt a jump start and nothing worked. My possible diagnosis is a bad fuel pump or relay, bad gas. Or a spark issue. When attempting to start you can slightly smell gas in the engine bay. Any help is much appreciated. I have a 7-hour trip to make in less than 2 weeks.
Monday, October 23rd, 2023 AT 9:29 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
It sounds like the engine has no spark, I would check out this video and confirm and change out the crankshaft angle sensor.
https://youtu.be/baq_aEWNQ0Y?si=sDe-4Bi-jfUSkoPg
Here is the location of the crankshaft angle sensor. Check out the images (below). Please let us know what happens.
Tuesday, October 24th, 2023 AT 8:45 AM
Related Engine Not Running Content
