HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Steering
Column
Replace/Remove
Steering column remove
BRIJCORNE
MEMBER
1996 FORD F-150
V8
2WD
AUTOMATIC
180,000 MILES
I am trying to find out how to remove a steering column and install it into my truck.
Sunday, September 3rd, 2017 AT 12:25 PM
KEN L
MASTER CERTIFIED MECHANIC
Start by disconnecting the battery. Here are some guides that will show you how it is done (below).
You will need to remove the airbag as well.
https://www.2carpros.com/articles/air-bag-removal-steering-wheel
Cheers, Ken
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, September 5th, 2017 AT 12:28 PM
Please
login
or
register
to post a reply.
Related Steering Column Replace/Remove Content
How To Replace The Steering Column With Tilt Wheel?
Replacing Center Rod, Bearings, Sleeve From Wheel To Tilt Section
Asked by
wicked417
1 ANSWER
22 IMAGES
1996
FORD F-150
Steering Column Actuator
Recently The Steering Column Actuator Failed On My Son’s Truck. I Managed To Get It Replaced And Everything Works Fine. However, I Took...
Asked by
ssbhart
2 IMAGES
1990
FORD F-150
Steering Column Replacement
I Replaced My 1999 F150 Xl No Tilt No Cruise With A 2000 Xlt Tilt And Cruise Model Sterring Column Hooked Everything Up Now The Truck Will...
Asked by
pascowater
1999
FORD F-150
1990 Ford F150 Dismantle 1990 Ford F150 Steering...
I Have What I Think Is A Broken Upper Ignition Acuator That Is Broke. Very Low On Cash And Trying To Fix This Myself. I Have Tilt Steering...
Asked by
vikingbj
1990
FORD F-150
Steering Column
Steering Problem 6 Cyl Two Wheel Drive Automatic 150000 Miles I Have A F-150 I Need To Take Out The Steering Column Is It All One Piece...
Asked by
crpowell08
2 IMAGES
1993
FORD F-150
VIEW MORE
SPONSORED LINKS
Steering Wheel Removal
Power Steering Pump Replacement
Steering Intermediate Shafts Replacement
Online car repair manuals
