Can't roll window up or down but motor is good. Can find white wire with green stripe.
Friday, September 27th, 2019 AT 4:17 PM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like a fuse or relay issue. here is a guide to help you check for power with the rear window wiring diagrams so you can see how the system works and which fuses and relays to test:
