This can be the headlight switch or the taillight relay, here is the location of the relay so you can swap it out which will be easy. Also, here is a guide to go over that can help as well:
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, April 30th, 2024 AT 11:36 AM
DANIEL HYATT
MEMBER
How do I change the relay? It's wires not a plug.
Wednesday, May 1st, 2024 AT 10:03 AM
KEN L
MASTER CERTIFIED MECHANIC
Can you upload an images of what you are seeing? The relay should just pull out from the relay box.
Thursday, May 2nd, 2024 AT 8:50 AM
DANIEL HYATT
MEMBER
How do I change the relay? Its wires not a plug
Thursday, May 2nd, 2024 AT 8:54 AM
DANIEL HYATT
MEMBER
Unsure I have the right location. What I found that looks like the images was behind the glove box under the dash.
SPONSORED LINKS
Thursday, May 2nd, 2024 AT 8:55 AM
KEN L
The relay should be on the backside of the fuse panel on the right side of the dash. Let me know, upload images please so I can confirm you have the correct relay.
