Engine will not stay running?
RODRIGOVZQZ
  • 2002 VOLKSWAGEN BEETLE
  • 1.9L
  • 4 CYL
  • TURBO
  • MANUAL
  • 200,000 MILES
Car cranks and starts for a few seconds and then shuts off. The diesel pump was replaced by the dealer 4 years ago and was working fine. Was automatic and turned into std. Traveled 2,000 miles trouble free and all of a sudden started acting up. I had to push start it once in reverse and started smelling like burned, as in electronic wires. Any advice?
Sunday, October 29th, 2023 AT 7:46 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
I would check the wiring harness for the engine to make sure nothing got pinched when installing the manual transmission. This is typical when an R&R occurs. Next check the fuses this guide can help, please check the fuses with the ignition system on:
If all fuses are okay let's run the codes to see if any are stored.
Monday, October 30th, 2023 AT 11:14 AM
RODRIGOVZQZ
  • 14 POSTS
Got p0753 and it's manual not automatic.
Friday, March 8th, 2024 AT 12:05 PM
RODRIGOVZQZ
  • 14 POSTS
Another thing is, to try to start it, it drags with a new battery. Have to use jumper cables.
Friday, March 8th, 2024 AT 12:17 PM
KEN L
  • 43,468 POSTS
It sounds like the battery is weak or you need a starter. Please upload a video in your response to the problem so we can see what's going on.
Saturday, March 9th, 2024 AT 9:49 AM
