Low pressure tire light, the light flashes yellow for a bit then goes solid, TPMS light?
SBMISRY
  • 2010 VOLKSWAGEN JETTA
  • 2.5L
  • 5 CYL
  • 152,000 MILES
This didn't start until after I did a vacuum pump delete. (Has battery out). When reinstalling battery, I arched out. So, I'm wondering if this could cause this.
Friday, January 12th, 2024 AT 3:54 PM
  • 108,489 POSTS
I know that to reset the TPMS system, it is important to maintain battery voltage to prevent issues. Do me a favor. Take a look at the directions I attached below for resetting the system. Let me know if you are comfortable performing what it explains.
Note that it indicates to keep a battery charger on while doing this because the key is on for a long time to perform the procedure. If you have a charger, make sure to do it. Also, let me know what you arced when installing the battery.
See pic below.
Friday, January 12th, 2024 AT 8:21 PM
