Transmission vibration?
SAMGREW
  • 2008 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 184,000 MILES
When accelerating the car vibrates side to side. Also, when turning left but not right.
Wednesday, March 13th, 2024 AT 3:49 PM
  • 108,489 POSTS
It could be the transmission is slipping, but that doesn't explain the turning issue. Also, when you say it vibrates side to side, I'm not sure I understand what is happening. Do you mean the front of the vehicle moves left and right? If so, have you checked the suspension and steering components?
I attached a pic below showing different things related to the suspension. Check to make sure everything is tight. Next, I circled the engine cradle or sub-frame. Check to make sure nothing is rusted, the bushings are in good condition, and the general overall condition appears to be fine.
See pic below.
Wednesday, March 13th, 2024 AT 8:08 PM
