Since then it will not Move in drive or reverse
LEELO
  • 2009 FORD RANGER
  • 4.0L
  • 6 CYL
  • 4WD
  • 99,999 MILES
Step in the accelerator to go to the passing gear an it slip badly. Since then it will not move in drive or reverse. If I take off in second an shift manually to Drive it will change gears to the proper gear but it will barely move the vehicle forward.
Thursday, November 8th, 2018 AT 5:27 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
It sounds like the input shaft speed sensor is out but to be sure lets run the codes to see what comes up. Also please check the fluid level and condition. Here is a guide and diagrams to help you get started:
Cheers, Ken
Saturday, November 10th, 2018 AT 10:20 AM
LEELO
No codes.
Saturday, November 10th, 2018 AT 2:58 PM
KEN L
  • 43,468 POSTS
Okay, can you check the fluid level do you see any leaks? Even if you do not have a codes for it the intermediate speed sensor can still be bad. Here is its location so you can check it out.
Monday, November 12th, 2018 AT 9:38 AM
LEELO
The pan leaks. I will be checking the sensor.
Monday, November 12th, 2018 AT 9:20 PM
KEN L
  • 43,468 POSTS
Low on fluid will cause this issue.
Tuesday, November 13th, 2018 AT 10:46 AM
LEELO
Okay, P0734 that I was able to get. Fluid is with in range.
Friday, November 16th, 2018 AT 3:21 AM
KEN L
  • 43,468 POSTS
I have seen the intermediate sensor go and cause this code. By out I mean misreading it still working but not correctly so it does not light the code for sensor failure. Lets try changing out the sensor to see what happens.
Friday, November 16th, 2018 AT 5:22 PM
