Lost my remote key, is there a way to manually open the hood?
TKODERP
  • 2004 LEXUS LS 430
  • 175,000 MILES
I’ve misplaced my remote key and I’m needing to access underneath my hood. Is there a way to manually pop the hood or enter through the Lexus emblem somehow?
Friday, June 17th, 2022 AT 10:48 AM
  • 108,489 POSTS
On the left side of the steering column, there should be a release lever that is attached to a cable and runs to the hood release.
If you look below, pic 1 shows the location it should be. Pic 2 just shows the lever. Locate the lever and gently pull it toward you. The hood should pop to open to the safety latch. Then you can release that by hand from the front of the hood.
Let me know if you find this.
Friday, June 17th, 2022 AT 8:41 PM
