Vacuum hose location and layout needed?
SHEPBARRICK
  • 2003 CHEVROLET S-10
  • 2.2L
  • 4 CYL
  • MANUAL
  • 87,000 MILES
I am having a vacuum leak my mechanic can't seem to figure out. The truck would start and run and then whilst driving the truck would just shut off randomly, like 1st and 2nd gear seems like it was having problems breathing, like it was chugging for air.
Now, the truck won't start, and I think it's because of low battery or start or honestly, I don't know. I'm not a mechanic at all but I can research. I just want a working vehicle so I can be the provider that I need to be. Any help at all would be appreciated so much so.
Sunday, February 11th, 2024 AT 5:57 AM
  • 108,489 POSTS
In most cases, a vacuum leak will not cause the engine to stall while driving. It can when at idle or initial acceleration, but once you are moving, that is unlikely the cause.
To me, if it stalls once you are driving, my first thought is a fuel issue or a failing crankshaft position sensor. Take a look at this link and let me know if anything mirrors what you experience:
So, if the battery is weak, we need to take care of that first. Is it possible for you to have it recharged? If you don't have a charger, most parts stores will do it for you.
Once that is taken care of and the starter properly turns the engine to start, I need you to try something. See if it will start if you use starting fluid. If it does and then stalls, we know it is a fuel-related problem. If there is no change, I need you to check for spark at the spark plugs.
Here is a link showing how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find. Also, let me know if you have other questions.
Sunday, February 11th, 2024 AT 4:10 PM
