Wiring harness pinout needed?
LANDON05
  • 1997 CHEVROLET 1500
  • 4.3L
  • 6 CYL
  • 4WD
  • 223,000 MILES
I need a firewall plug diagram for a 1997 k1500.
Friday, February 23rd, 2024 AT 1:46 PM
  • 108,489 POSTS
I believe I have the correct one for you. It should be a light gray, 36 pin connector. If that is incorrect, let me know.
If you look below, pic 1 is the connector. The remaining pictures indicate the function of each of the connector pins, wire color, wire gauge, and so on.
Take a look through this and let me know if this is what you need.
Friday, February 23rd, 2024 AT 10:08 PM
LANDON05
Yes, I think that’s right but by any chance is that a difference in that plug and a 1998 k1500 with a 5.7? If so, I need a pinout for that too.
Sunday, February 25th, 2024 AT 7:58 AM
  • 108,489 POSTS
They appear very similar, but there are a few differences. What I recommend is to print out the information I provided and do a side by side comparison.
If you look below, I attached the info for a 98 with the 5.7L.
Let me know if this helps.
joe
Sunday, February 25th, 2024 AT 6:40 PM
LANDON05
Is there any difference between a regular k1500 and a work truck model? Just asking.
Monday, February 26th, 2024 AT 11:13 AM
LANDON05
The 1997 is a work truck and I didn’t know if that would make a difference in the plugs.
Monday, February 26th, 2024 AT 11:16 AM
  • 108,489 POSTS
I double-checked and that is the only one for a 98. I suspect there may be connector wires that may or may not be used based on options.
Monday, February 26th, 2024 AT 7:23 PM
Related General Content
