4 Wheel Drive doesn't Work?
ADAM_WORLEY06
  • 1994 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 200,000 MILES
I engaged it to 4 wheel drive, and I felt it engage. But when I was on ice, the front wheels didn't spin. The light does not come on even when it is engaged. This is my first 4x4 and I don't know much about it. Any ideas what I need to make it work? Thanks.
Tuesday, January 26th, 2010 AT 7:44 AM
SCOTTY DEE
  • 592 POSTS
Check AC/HTR fuse first. Check for feed wire problem at transfer case switch, possible open. Also inspect wires to actuator, and inspect actuator for damage.
See the guide below on testing wiring
Wiring diagram for your 4wd system is attached below
Tuesday, January 26th, 2010 AT 2:47 PM
CLOPEZ78
  • 5.7L
  • V8
  • 4WD
  • 240,000 MILES
After replacing both CV axles 4 wheel drive not engaging even after replacing actuator.
Wednesday, September 2nd, 2020 AT 10:54 AM (Merged)
  • 108,489 POSTS
First, check the 4wd fuse to make sure it is good. In addition to just checking the fuse, make sure there is power to it. If that is good, there is a black wire coming from the actuator on the axle. Make sure it has continuity to ground.
I attached a pic below of the fuse and a portion of the wiring schematic. Here is a link you may find helpful when testing for power at the fuse:
Let me know. Also, if the fuse is good, I need to know if the 4wd light is turning on and if there is power to the actuator.
CLOPEZ78
Thank you for your response.I checked the fuses everything is work the light doesn't come for the 4 wheel drive I bought a new actuator it seems to be working fine.
  • 108,489 POSTS
Do you mean the actuator is working fine or everything is working fine?
CLOPEZ78
Yes actuator is working fine and fuse is good, but it still does not engage. I don't what is going on, it is weird it was working fine be for I replace the CV axles.
  • 108,489 POSTS
Check to see if there is power to the front axle solenoid switch. I attached a pic for you. You should have 12v to blue wire.
MAINTENANCE
  • V8
  • 4WD
  • 190,000 MILES
Truck had sat all summer and the front wheels had frozen in the dirt, tried breaking it free in four wheel drive, heard a bang and rear wheels spun but not the front. I got it pulled out with a tractor, and now four wheel drive does not work in 4H or 4L, works and drives fine in 2H. Also the 4x4 indicator light on the floor comes on when I shift into 4x4, but only have rear wheel drive.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
It sounds like something broke. Can you confirm the front driveshaft turns? Here is an exploded view of the transfer case. Check the encoder it might not be working right. If everything looks okay here is how you rebuild the transfer case the instruction and diagrams are below. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
MAINTENANCE
Front drive shaft does turn, so thinking something in the front differential let go.
KEN L
  • 43,468 POSTS
Can you remove the driveshaft to see if the transfer case still works? Here is a guide to help:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
MAINTENANCE
The truck drives okay. I can shift transfer case into 4 lo and all other ranges just fine, but only have two wheel drive. When I shift to 4 lo the truck drives in low gear just fine.
KEN L
  • 43,468 POSTS
Yep, it sounds like something let go inside the transfer case, it will need to be removed and disassembled. Use the diagrams above to help take it apart to see what happened. Please upload pictures of the damaged parts once you get it apart. We are interested to see what it is.
BARNEY SMITH
  • 5.7L
  • V8
  • 4WD
  • 234,000 MILES
Replaced actuator and shifter switch will now go in 4 low but not 4 high. Have power on 4 low wire but not on four high at the shifter switch.
Wednesday, September 2nd, 2020 AT 10:55 AM (Merged)
  • 108,489 POSTS
I attached a portion of the wiring schematic. Are you getting power to the dark blue wire and not the light blue?
Have you checked the switch itself? If you look at pics 2 and 3, I provided the schematic for the system. If you look, power is provided via a brown wire to the transfer case switch. From there, low or high 4wd is determined. If low works, then we know power is available to the switch. If it isn't changing out of 4 low, confirm the fuse is good (indicated in pic) and power is to the switch. If you have power and 4low works properly when in 4wd, the I suspect the switch is bad.
Here are a few links you may find helpful:
BOBBY123456789
  • V8
  • 4WD
  • MANUAL
  • 225,000 MILES
My four wheel drive will not engage what could be problem?
  • 108,489 POSTS
Check to see if there is power to the 4wd actuator on the transfer case (if it is the electric shift). If it has the lever on the floor, check the linkage to the transfer case. If it is good, tight, and properly adjusted, check to make sure the actuator on the front axle is working. There is an updated actuator for these, the originals had issues
See diagram below
JCHEECH
  • 2.5L
  • V8
  • 4WD
  • 200,000 MILES
4 wheel drive will not engage now, when I try, to engage only one wheel spins. My 4 wheel drive light does not come on when I shift it into 4 wheel drive.
HMAC300
  • 48,600 POSTS
Check both switches in pic for power they are both on front axle. But normally only one wheel spins anyhow unless it's positraction
SCHUELERAUTOSERVICE
  • 8 POSTS
Also make sure your front propellor shaft spins and I would check the front actuator pin the slides to engage front shaft almost directly under the engine and may have to remove to see if its seized. Check for power there first.
