Crankshaft position sensor location for replacement please?
HAYDERAZ
  • 2014 CHEVROLET IMPALA
  • 66,000 MILES
Where is crankshaft position sensor located on 2014 impala LT 2.5L (new body) Thanks
Thursday, May 16th, 2019 AT 6:05 PM
Hi Hayderaz,
I attached an exploded view of the engine block and it shows the crank sensor location. I circled it in red just in case.
Please let me know if you need anything else. Thanks
Thursday, May 16th, 2019 AT 7:11 PM
HAYDERAZ
Thank you for your help but I did not find it. Do you mean I need to open the engine?
Friday, May 17th, 2019 AT 9:44 AM
No. That was the only view that they gave in the shop manual to show where it is located. However, I didn't think to look at the replacement procedure. Here is a different view. Looks like it is behind the exhaust pipe on the side of the engine block.
Friday, May 17th, 2019 AT 10:25 AM
JOE REYES
  • 2012 CHEVROLET IMPALA
  • 3.6L
  • V6
  • 96,141 MILES
Hello guy's I'm in need of some assistance. Have the car listed above don't know exactly the location of the crankshaft position sensor and don't know if there's more than one. And information on how to change the sensor and procedures if need to program or if there any re-calibration necessary. Thanks in advance!
Wednesday, March 17th, 2021 AT 5:12 PM (Merged)
I attached the info for the CKP sensor. There is only one so you just need to access it by removing part of the exhaust. Let me know if you have questions. Thanks
JOE REYES
Thanks for the info. Looking at the diagram of the whole motor it's correct. Only the top end of mind the air intake is opposite from the image. The only way I see myself accessing it would be take the driver wheel off and reaching. I'm not to sure if that would be a good approach?
Sorry for the delay. Yes. That is very common to have to remove one of the wheels to access it on engines with transaxles.
ARTHUR HEDRICK
  • 2010 CHEVROLET IMPALA
  • 3.5L
  • 6 CYL
  • 110,000 MILES
Car would stall every now and then, but start back up. Online diagnosis either mass air flow sensor or crank sensor. Bought both; first mass sensor was wrong one even when given the VIN. Got the right in and it started acting up more. Went to change crank sensor but the sensor I took out according to them comes back as speed sensor. If you search the part number online first says it is crank sensor for 3.4 engine. So I looked online to change crank sensor again but only see the one that they say is speed sensor. They are AutoZone and the part number in question is 10456568 m (ie Crank Sensor). I need to maybe see a diagram or picture so I can find crank sensor, to change it out. Any help would be appreciated. Thank you
STEVE W.
  • 13,150 POSTS
The GM part number for the crank sensor on that engine is GM# 12598208 it is the one in the image. The part number you have (10456568) is the transmission output speed sensor. The crank position sensor is on the firewall side of the engine, just above the oil pan lip and in line with the exhaust outlet on the manifold. To get to it you go under the car, then unplug the sensor, remove it and reverse the process to install the new one. They have a habit of sticking in the block so you may want to remove it with a warm engine and gently work it out of the bore.
Once replaced you need to use a scan tool to do a CKP relearn procedure so the ECM knows the signal levels of the new sensor.
2SOLID2FALL
  • 5 POSTS
  • 2008 CHEVROLET IMPALA
  • 5.3L
  • V8
  • 142,750 MILES
I don't know where the crankshaft position sensor is located on my car listed above SS model.
Take a look at this information. This is the location and replacement information. Let us know what other info you need. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks
MATTHEW MCDOWELL
  • 2007 CHEVROLET IMPALA
  • 5.3L
  • V8
  • 181,000 MILES
Cannot find the crankshaft position sensor.
Wednesday, March 17th, 2021 AT 5:13 PM (Merged)
  • 52,797 POSTS
Good evening.
The crank sensor is behind the right exhaust manifold. The manifold needs to be removed to gain access to the sensor.
Removal Procedure
Caution: Refer to Vehicle Lifting Caution in Service Precautions.
1. Remove the right exhaust manifold.
2. Disconnect the crankshaft position (CKP) sensor electrical connector (1).
Important: Clean the area around the CKP before removal in order to avoid debris from entering the engine.
3. Remove the CKP sensor bolt.
4. Remove the CKP sensor.
Right manifold
1. Remove the engine sight shield.
2. Remove the spark plugs.
3. Remove the exhaust crossover pipe nuts from the right exhaust manifold.
4. Disconnect the catalytic converter from the exhaust manifold.
5. Support the catalytic convertor and exhaust system with the mechanics wire.
6. Lower the vehicle.
7. Remove the ignition coil.
8. Remove the O2 sensors.
HERSHEY81
  • 3.5L
  • V6
  • 250,000 MILES
Need help locating CPS. Code P0336 pops up.
Wednesday, March 17th, 2021 AT 5:14 PM (Merged)
AL514
  • 4,199 POSTS
Hello, thanks for using 2CarPros. here is a diagram locating the crank position sensor. It is located under the exhaust manifold about half way back on the engine block.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
GREG STONE
  • 3.5L
  • 6 CYL
  • 217,000 MILES
Had new computer and fuse box installed went and got new crank sensor, my buddy went to put in and cut off connector and don't think he wired them back right. Need to know what color goes to what. Still no RPMs and idle very rough won't throttle up.
  • 52,797 POSTS
Good morning,
I attached the connector view for you below with the terminal identifications.
Crankshaft Position Sensor Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Disconnect the crankshaft position (CKP) sensor electrical connector (4).
3. Remove the CKP sensor stud.
BMAN91
  • 2006 CHEVROLET IMPALA
  • 5.3L
  • V8
  • 240,000 MILES
Where exactly is the crank shaft position sensor located on the listed above it is the SS model.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Here is a guide that will show you what you are in for when doing the job:
Here is the location for your car.
Check out the diagrams (below).
Cheers, Ken
FORTEJETS18
  • 2005 CHEVROLET IMPALA
  • 6 CYL
  • FWD
My car has a bad Crankshaft position sensor. It's a 2005 chevy impala, 3.4 and I know there are two possible places where it could be. Can you tell me the exact place they would be located?
