Dash lights and rear lights not working
TJMAMA96
  • 2012 VOLKSWAGEN JETTA
  • 4 CYL
  • 71,339 MILES
Where can I tell which fuse is for what. In the fuse box? There is nothing saying what fuse is for the radio, or the tail lights or the instrument cluster.
Friday, May 27th, 2016 AT 8:14 PM
  • 31,937 POSTS
We need to check fuse #23, 10, 14 and 16 in the fuse panel inside the car and under the hood here is a guid to help you with the fuse locations and the wiring diagrams so you can see how the system works below.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Friday, May 27th, 2016 AT 9:47 PM
J.STIEG
  • 352 POSTS
  • 2001 VOLKSWAGEN JETTA
  • 150,000 MILES
Having a problem with the tail lights in the rear driverside.
#23 5a fues keeps blowing.
Also the instrument cluster ilumination lights do not come on.
Monday, April 13th, 2020 AT 11:13 AM (Merged)
KHLOW2008
  • 41,814 POSTS
If the taillight fuse blows, the instrument cluster illumination would not work. There is a shortin somewhere and if you have any impact damagges to fron ot rear of vehicle check the wirings for shorting to body. Disconnect all taillight bulbs and test if fuse still blows.
J.STIEG
  • 352 POSTS
Ok I disconnected all main connectors front and back to all lights in every corner of the vehicle. Fues #23 still blowes
CARADIODOC
  • 33,765 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
J.STIEG
  • 352 POSTS
Is fues #23 a 5a?
Also need diagrams? Got to get this fixed soon. Thanks
CARADIODOC
  • 33,765 POSTS
Hope KHLow2008 can help with that. I've never been able to access the wiring diagram section. We do have links here for Mitchell service manuals. I can also send you to AllData if that will help.
J.STIEG
  • 352 POSTS
Where exactly does #23 go. How many things does #23 power. Need to see some wire routing.
CARADIODOC
  • 33,765 POSTS
This link will take you to Mitchell Manuals:
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
This one will take you to my web site with an ad on top for AllData:
http://randysrepairshop.net/index.html
I have a lot of stuff for troubleshooting electrical problems but nothing specific to your car. Mitchell is less expensive and they have always had really good wiring diagrams. I wish I could get into those sites to get a diagram for you. Hopefully KHLow2008 will be able to when he sees your reply.
EXOVCDS
  • 1,883 POSTS
Are you sure the problem is in the back?
Did you check the front left side marker in the bumper?
How's the amber bulb in the front headlight assembly?
Thomas
EXOVCDS
  • 1,883 POSTS
- #92 goes to front left side marker
- #115 goes to left tail light
- #98 goes to left park light (front)
Thomas
EXOVCDS
  • 1,883 POSTS
Forgot image. Sorry.
Still getting used to new website layout.
Thomas
J.STIEG
  • 352 POSTS
Thomas,
can you post that diagram again, only without the red arrows. Thanks
J.STIEG
  • 352 POSTS
Never mind, I think they are all GR/SW. Thanks
Once again every thing is unplugged FRONT and BACK Side to side and fues #23 is still blowing.
I will try disconnecting power to cluster to.
CARADIODOC
  • 33,765 POSTS
Put the light bulb in there. Why keep on buying fuses? Instead of doing a bunch of stuff, then installing and blowing another fuse, just see what makes the bulb go out. WAY more efficient and less costly.
J.STIEG
  • 352 POSTS
The #23 fues ONLY blows when the HEADLIGHT SWITCH is on, but with all lights unplugged in every corner.
I have the test light bulb looped in series on #23, and all lights UNPLUGGED. I now turn the headlight switch on, but TEST LIGHT comes on.
Right now I am trying to get the test light off, with headlight switch on, and of course every light unplugged.
Trying to find a place to unplugg at firewall to see if problem is in the front or back, Any ideas?
J.STIEG
  • 352 POSTS
There are 10 wires going to the headlight switch. I need to know what they are, and test them for shorts.
If I unplug headlight switch connector the test light on fues #23 goes out.
KHLOW2008
  • 41,814 POSTS
See if this diagram is of any help.
J.STIEG
  • 352 POSTS
Thanks KHLow2008 for the diagrams! I found the problem using the diagrams.
It was a left front small amber running light shorted out.
KHLOW2008
  • 41,814 POSTS
Glad to know you have fixed the problem.
