I am looking to put in an oil catch can pcv valve location please?
Wednesday, November 3rd, 2010 AT 2:47 PM
KHLOW2008
MECHANIC
Hi cldchln,
2005 Ford Expedition and 2007 F150 are similar.
Item # 6 is the PCV hose. The valve is plugged into the valve cover.
2005 GMC Sierra 1500.
PCV hose is item # 716, (dirty air ) and # item # 700, (fresh air).
2007 Toyota Tundra
SPONSORED LINKS
Sunday, November 7th, 2010 AT 3:36 AM
KIMMY4400
MEMBER
2004 FORD EXPEDITION
172,000 MILES
Where is the pcv valve location in a 2004 4.6 ford expedition
Thursday, September 12th, 2019 AT 2:43 PM
(Merged)
HMAC300
MECHANIC
In the valve cover rh side see pic
Image (Click to make bigger)
(Merged)
KIMMY4400
MEMBER
Can you send me a pic of the pcv part that I need to purchase. Also I've looked everywhere trying find the location where I need to replace the valve doesn't look the same as the diagram in my vehicle. Is there another truck thats compared to the 2004 4.6 ford expedition has the same location
(Merged)
KIMMY4400
MEMBER
Thanks for the information
SPONSORED LINKS
(Merged)
HMAC300
MECHANIC
I sesnt a diagram of where it was located. Check rock auto. Com for part
(Merged)
HMAC300
MECHANIC
See if these help you the pcv may unscrew for removal on LH side of engine (driver's side)
Images (Click to make bigger)
(Merged)
KIMMY4400
MEMBER
Thanks again. Another question I have can you also send me a diagram of where my upstream oxygen sensors are located in my 2004/ 4.6 expedition
(Merged)
HMAC300
MECHANIC
They are the ones between engine and converters on exaust system. See pic. Please repost a new question like this as a lot of times they are not answered
(Merged)
MELISSA1001
MEMBER
1 POST
107,000 MILES
Is the valve located under the plastic cover or on the driver's side of the cover, just below? I asked the person at an automotive store but they were unsure of it's location. A picture would be helpful.
(Merged)
SATURNTECH9
MECHANIC
The PCV valve is located in the upper portion of the valve cover. Here is a diagram of the 4.6L or 5.4L engines below.
(Merged)
KIMMY4400
MEMBER
Thanks so much I appreciate your help. The second diagram was a lot more accurate
SPONSORED LINKS
(Merged)
BIGLEE33
MEMBER
2003 FORD EXPEDITION
V8
4WD
AUTOMATIC
89,060 MILES
I would like to know exactly where my pcv tube is located and if it will be difficult to replace for the user.
(Merged)
MECHANIC
What size engine do you have?
(Merged)
BIGLEE33
MEMBER
I have the 4.6 Liter.
(Merged)
MECHANIC
Here are the pictures I found. It is on the valve cover.
Let me know if this helps. NOTE: These pictures are from Ford, so I will assume they are correct.
(Merged)
BIGLEE33
MEMBER
Thank you so much! I was just wondering about that very hose. I will let you know if it works out.
(Merged)
ELLIOTT37
MEMBER
1 POST
V8
2WD
AUTOMATIC
80,000 MILES
Bought a pcv vave and cannot find it on the engine
(Merged)
MECHANIC
Hi:
It's located on the valve cover. Here is a picture.
(Merged)
SABRUIN
MEMBER
1 POST
1999 FORD EXPEDITION
6 CYL
2WD
AUTOMATIC
144,000 MILES
I was told by the service tech at the Ford dealership we take our vehicle to that the PCV tube is collapsed. Can you tell me where it is and how to replace it? A diagram or photo would be helpful. Thanks!
(Merged)
