Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. If this is not correct please tell us why in the vote comments.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, August 16th, 2016 AT 10:01 AM
CUTE_LIL_BLONNDE1245
MEMBER
1 POST
2003 FORD RANGER
I am not getting fuel to the engine. I was wondering if it it is the fuse and where is it located?
Wednesday, February 3rd, 2021 AT 1:32 PM
(Merged)
MERLIN2021
MECHANIC
There is a relay, an inertia switch, and wiring. Check to see if the pump can be heard for 2-3 seconds when the key is turned to on. See if the red button on the inertia switch is pressed down. (Below)
The inertia switch is on the right front kick panel.
(Merged)
REMI6183
MEMBER
2001 FORD RANGER
6 CYL
2WD
AUTOMATIC
Where is the alternator charging fuse located?
Wednesday, February 3rd, 2021 AT 1:33 PM
(Merged)
MECHANIC
Its fuse no.11 7.5 amp its in the central junction box behind left side of dash here is a guide and the fuse panel location and identification below.
Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
Wednesday, February 3rd, 2021 AT 1:34 PM
(Merged)
SCHAUT78
MEMBER
1998 FORD RANGER
4.0L
6 CYL
4WD
AUTOMATIC
160,000 MILES
Windows not working. Need relay placement for box under dash with eight relays in it.
(Merged)
STEVE W.
MECHANIC
Fuse 4 in the under-hood box is power windows and locks as well as power seats. The under dash box contains only the one touch relay for the windows. The accessory delay relay is the other window related relay. The rest is controlled through the GEM module.
The AD relay is on its own connection not in the relay box.
(Merged)
SCHAUT78
MEMBER
Awesome thanks so much.
SPONSORED LINKS
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Nice work Steve,
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
(Merged)
BILLIYJO21
MEMBER
1 POST
1996 FORD RANGER
4 CYL
2WD
MANUAL
17,300 MILES
I have a 1996 ford ranger with the 2.3l engine and one day the fuel pump went out and so we tested the pump and it was fine we came to find out that it wasnt getting any power so I was wondering if and were the fusible link would be located
thanks joey
Wednesday, February 3rd, 2021 AT 1:35 PM
(Merged)
MECHANIC
Check fuse 20amp fuel sys/anti theft in engine fuse/relay box, fuel pump relay and PCM power relay-
If it were the fusible link you would have lost power to more than just the fuel pump, it doesn't have its own power feed
Read the guide below on testing relays, it will help
I attached the legend and pictures of both fuse boxes for you. Check out the diagrams (Below). Please let us know what happens. Let me know if you have any other questions.
Wednesday, February 3rd, 2021 AT 1:37 PM
(Merged)
ROCHILD
MEMBER
1994 FORD RANGER
170,000 MILES
I need to identify a fuse that was burned in my truck. I do not have any written information of my truck. This box is under the motor capo, near the battery. Could anyone help?
(Merged)
MECHANIC
Here are two guides that will help you test the fuse and relay for your truck.
Cheers
(Merged)
ROCHILD
MEMBER
If I stand near the left tire, on top of the box I see relays in the middle fuses (mini)in bottom fuses ( big) one of it is 60 A capacity. My truck has the power distribution module at the left side.
Thanks for the diagrams worked great I saved this page in my favorites.
