Passenger side window does not work
KUMAR-O
  • 2001 FORD WINDSTAR
Passenger side window does not work. All the other windows work. What should I check? Where can I get an electrical diagram?
Tuesday, April 20th, 2010 AT 12:19 PM
  • 108,489 POSTS
I would start by checking for power to the P/W motor. If there is no power, move to the switch to see if power is there.
Wednesday, May 12th, 2010 AT 1:36 PM
01WINDSTARANDI
  • 6 POSTS
I have a similar problem on the driver's side window, 2001 Windstar limited, 230,000 miles. Passenger window & 1 of the aft windows still work. I have replaced the motor, it worked for a couple of weeks then stopped. Then I replaced the master switch pack on the drivers side, it still doesn't work. It sounds like a relay is engaging when the switch is pressed, but no window movement. Is there a wiring diagram available? I'm going to check the harness for shorted and/or broken wires.
Saturday, January 6th, 2018 AT 7:30 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Yes here is the power window wiring diagram and a guide to help you do some testing in case you need it.
Check out the diagrams (Below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Monday, January 8th, 2018 AT 1:56 PM
RLEEMAN
  • 6 CYL
  • FWD
  • 13,200 MILES
Electrical problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic 132, 00 miles
power window will not operate. I hear a clicking sound under dash when switch is operated. This began last summer. Window would operate when outside temperature approached 70 degrees. Nothing all fall and winter. Recently on the warmest day this year it began operating, only to stop as it has cooled off. Forecast is for 70+ weather next week. I have my fingers crossed. I'm not making this up.
Monday, January 8th, 2018 AT 1:57 PM (Merged)
  • 108,489 POSTS
It sounds like either a bad relay or the motor itself is bad. Have you checked to see if the motor is getting power? Have you tried switching out the relay with a known good one?
01WINDSTARANDI
  • 6 POSTS
I have a similar issue. 2001 model. I have replaced the motor & switch pack on this window. It worked for a couple of weeks after the motor replacement, then stopped. No help with switch replacement.
Can you tell me the which relay and the location of it?
Is there a diagram available?
Thanks!
FREDALS
  • 6 CYL
  • 185,000 MILES
Power windows don't work as well as the radio, Ac, Blowers and Gauges. Checked all fuses I think seem ok! Fred
Thursday, June 6th, 2019 AT 2:57 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
This sounds like the accessory delay relay is bad which is common here is the location so you can change it out with a guide to confirm the failure.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
FREDALS
Checked both sides of fuses all have power! All the inside lights work and so do the power supplies or cigarette lighter Fred
WRENCHTECH
  • 20,758 POSTS
Yep, I would check the relay can you find it?
FREDALS
Yep you nailed it, I got a new relay and plugged it in and BAM all fixed, I love this site.
WRENCHTECH
  • 20,758 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
CRITTERUSMC
Push buttons for auto windows and they dont go down or up checked the fuses and still not working
Thursday, June 6th, 2019 AT 2:58 PM (Merged)
HMAC300
  • 48,600 POSTS
I tmay be the switch for it check items in pic then have it scanned because it may be the front electronic module
GAMEOVER1173
  • 6 CYL
  • 176,000 MILES
I have a 2001 ford winstar that has a passanger power window problem. The window quit working, so I pulled the door panel off and I am only getting 7.5 volts when activating the switch. What could be the problem here? Thanks in advance for any help
WRENCHTECH
  • 20,758 POSTS
You'll have to test the power coming into the switch to determine if the switch is the problem or not.
GAMEOVER1173
I have tested it at the switch and that is what I got was 7.5 volts when pressed. The voltage is also low when tested at the motor as well
WRENCHTECH
  • 20,758 POSTS
Your only testing the power OUT of the switch, not the power INTO the switch.
GAMEOVER1173
So if I tested the voltage going into the switch is low do I replace the switch? Can you give me some solutions?
DKIMMERLY
  • 2000 FORD WINDSTAR
  • 6 CYL
  • 165,000 MILES
The power window has quit working in the passenger side door. I am attempting to take the door panel off and have a look. Are there any special things I need to be aware of when I take the door panel off and what might be the reason the window quit working, what should I look for? Thank you
