Fuel filter location
GARY NORDLAND
  • 2009 FORD EXPLORER
  • 4.0L
  • 4 CYL
  • 4WD
  • 150,000 MILES
Where is fuel filter located?
Tuesday, September 10th, 2019 AT 2:15 PM
  • 52,797 POSTS
Good afternoon,
It is in the back of the truck by the tank. This video will help you remove the filter with instructions below to show you how to replace the fuel filter in your car.
https://youtu.be/Boi0DPXVHbM
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
The procedure is below with some pictures.
WARNING: Do not smoke, carry lighted tobacco or have an open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited. Failure to follow these instructions may result in serious personal injury.
WARNING: Before working on or disconnecting any of the fuel tubes or fuel system components, relieve the fuel system pressure to prevent accidental spraying of fuel. Fuel in the fuel system remains under high pressure, even when the engine is not running. Failure to follow this instruction may result in serious personal injury.
WARNING: When handling fuel, always observe fuel handling precautions and be prepared in the event of fuel spillage. Spilled fuel may be ignited by hot vehicle components or other ignition sources. Failure to follow these instructions may result in serious personal injury.
NOTE: During the repair or replacement of fuel-related components, all liquid and vapor fuel openings must be capped, taped or otherwise appropriately protected to prevent the ingress of dirt or other contamination. All caps, tape and other protective materials must be removed prior to installation.
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Release the fuel system pressure.
3. Disconnect the battery ground cable.
Explorer/Mountaineer
4. Remove the 3 bolts and the fuel filter heat shield.
- To install, tighten to 20 Nm (177 lb-in).
All vehicles
5. Remove the 2 nuts and the fuel filter shield.
- To install, tighten to 6 Nm (53 lb-in).
6. Disconnect the fuel supply tubes quick connect couplings.
7. Remove the fuel filter.
8. To install, reverse the removal procedure.
Tuesday, September 10th, 2019 AT 2:50 PM
94 TRANSAM
  • 680 POSTS
Hi Gary, welcome to 2CarPros.
You will find a diagram below showing the fuel filter location. The fuel filter is number 5. If you need any further help please let us know.
Rich.
GARY NORDLAND
  • 4.0L
  • 4 CYL
  • 4WD
  • 150,000 MILES
Wednesday, October 7th, 2020 AT 1:10 PM (Merged)
If you look on the passenger side under the front part of the front door, you will see the catalytic converter and the filter is behind the heat shield that is attached to the frame. That is where this procedure picks up. See attached for more detail.
If you still can't find it, let me know and I can get you more detail. Thanks
DUKE35
  • 2006 FORD EXPLORER
2006 Ford Explorer 6 cyl Two Wheel Drive Automatic
i have a 06 ford explorer. I need to know where my fuel filter is located
TECHS IN
  • 14 POSTS
Located on the right side on the far side of the frame, also has an aluminum or metal heat shield around it. This shield it usually held on by a strap or 2 bolts. The fuel lines require a special tool to remove them. Hope this helps! Be sure to release the fuel pressure at the port before removing the lines.
STEVEN3622
  • 2005 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 103,000 MILES
Location of the fuel filter please, I need to change it.
DAVE H
  • 13,383 POSTS
The fuel filter is located near the front of the gas tank here is a guide to help walk you through changing it and the location of the filter with instruction on how to change it for your car below.
and to undo the lines
NEIL N DEVON BRIDGES
  • 2004 FORD EXPLORER
  • 4.0L
  • 6 CYL
  • 4WD
  • 200,000 MILES
Where is fuel filter?
  • 108,489 POSTS
Welcome to 2CarPros.
It is in front of the fuel tank behind a protection shield. See picture 1.
Here are the directions for fuel line/fuel filter replacement. The additional attached pictures correlate with the directions.
_______________________________________--
PROCEDURES
FUEL LINES AND FUEL FILTER
Disconnect Tool, Push Connect
pic 1
SPECIAL TOOL(S)
REMOVAL
3. WARNING:
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and can be ignited, resulting in possible personal injury.
- Fuel in the fuel system remains under high pressure even when the engine is not running. Before servicing or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel, which can cause personal injury or a fire hazard.
4. NOTE: This step is necessary for fuel tube removal and installation only.
Remove the transmission.
Pic 2 and 3
5. Remove the parts in the order indicated in the illustration and table. To remove individual parts, only carry out the listed steps.
Items 1 and 2: Fuel Filter Shield and Nuts Removal Note
pic 4
1. Remove the nuts and the heat shield.
Items 3 and 7: Push Connect Fitting Removal Note
pic 5
1. WARNING:
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
If equipped, disconnect the safety clip from the fuel tube.
Pic 6
2. Install the special tool and press it into the fitting.
Pic 7
3. Separate the fittings.
Item 4: Quick-Connect Fitting Removal Note
pic 8
1. WARNING:
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present an may be ignited, resulting in possible personal injury.
Unclip the tab.
Pic 9
2. Depress the tabs and press the clip downward.
Pic 10
Items 6 and 8: Quick-Connect Fitting Removal Note
pic 11
1. CAUTION:
- Fuel injection equipment is manufactured to very precise tolerances and fine clearances. It is therefore essential that absolute cleanliness is observed when working with these components. Always install blanking plugs to any open orifices or tubes.
- When reusing liquid or vapor tube connectors, make sure to use compressed air to remove any foreign material from the connector retaining clip area before separating from the tube.
NOTE: If the fuel tube retainer clip is broken or damaged, install a new clip using a suitable fuel line disconnect tool to separate the retaining clip legs. Once the retainer legs have been separated, lift the clip out of the connector housing, lifting from the stamped side of the connector body.
Disconnect the quick-connect fitting.
- Push the connect toward the tube to release the pressure.
- Press the locking button and pull the fuel tube to disconnect.
INSTALLATION
1. To install, reverse the removal procedure.
Items 8 and 6: Quick-Connect Fitting Installation Note
pic 13
1. CAUTION:
- Make sure the quick-connect fitting clicks into place when installing the tube. To make sure that the quick-connect fitting is fully seated, pull on the tube.
NOTE:
- If the fuel tube retainer clip is broken or damaged, install a new clip using a suitable fuel line disconnect tool to separate the retaining clip legs. Once the retainer legs have been separated, lift the clip out of the connect housing, lifting from the stamped side of the connector body.
- Apply clean engine oil to the end of the tube before connecting the fitting.
Connect the quick-connect fitting.
Items 7 and 3: Push Connect Fitting Installation Note
pic 14
1. NOTE: Lubricate the fuel fitting with clean engine oil.
Align the fuel line fitting and press together until a click is heard.
- Pull on the fitting to make sure it is fully engaged. If equipped, install the safety clip.
Let me know if this helps.
Wednesday, October 7th, 2020 AT 1:11 PM (Merged)
CYNTHIALYN
  • 6 CYL
  • 96,288 MILES
Looking under the car, I can't locate my fuel filter. Can you help
On the 2004 ford explorer the fuel filter is located under the vehicle on the passenger side near the rear of the passenger seat
MCKINNIES
  • 6 CYL
  • 4WD
  • 153,000 MILES
Where is the fuel filter located on my 2004 ford explorer.
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is located on the leading edge of the fuel tank, on right side of vehicle, mounted behind the fuel filter shield
RONNIEC56
  • 4 CYL
  • 85,300 MILES
Where is the fuel filter located on this vehicle
MERLIN2021
  • 17,250 POSTS
Look on the frame, by the right rear tire, follow it to the front till you find it!
CHAD HODSON
Xlt 4x4 4.6l v8 Where is the location of the fuel filter?
MIKE H R
  • 3,094 POSTS
The fuel filter is on the frame under neath drivers side door, in front of the fuel tank, it is covered by a protective shield
STEINZ21
I have a 2004 Explorer XLT 4.0 L v-6 flexfuel 4x4.
I can't locate the fuel filter. Can anyone help? The people at the parts stores keep saying it is along the frame rail. I have checked the frame rail, and it isn't there. On my old explorer (1996) that is where it was.
PSNOWDEN
The fuel filter will be on the inside of the frame next to the gas tank with a plastic clip on each end.
