Fuel pump relay location?
TRIPSLUV
  • 2008 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 168,732 MILES
I cannot find my fuel pump relay location. Also, does my car have a fuel pump reset switch?
Wednesday, July 3rd, 2019 AT 6:59 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
There is no reset switch.here is a guide to help you test the relay which is inside the IPDM in the engine compartment:
Thursday, July 4th, 2019 AT 2:31 PM
TRIPSLUV
I still can't find it. I don't understand those diagrams. Is it inside the car or under the hood?
Friday, July 5th, 2019 AT 12:57 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The fuel pump relay is located in the IPDM (intelligent power distribution module) which is located under the hood on the left side near the strut tower. I've attached a picture below. Hope this helps and thanks again for using 2CarPros.
Danny-
Saturday, July 6th, 2019 AT 5:40 PM
HAROLDNASHJR
  • 2006 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 150,000 MILES
Where is the fuel pump relay location? What does the relay look like?
Tuesday, May 25th, 2021 AT 1:31 PM (Merged)
  • 108,375 POSTS
Welcome to 2CarPros.
The relay is located in the under hood power distribution box. I attached a picture which shows the relay location for you. Pic 2 is a general picture of a fuel pump relay.
Here is a link that explains how to check a relay:
Here are a few additional links you may find helpful:
Check out the diagrams (Below). Please let us know what you find.
SCGRANTURISMO
  • 4,897 POSTS
The relay is located in your vehicle's Intelligent Power Distribution Module (IPDM) which is located on the right front of the engine compartment, right behind the headlight. In the diagrams down below I have included diagrams for the location of the IPDM and a diagram with the fuse and relay locations in the module itself. Here is a link for how to test a relay, if needed:
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
HAZEY83
  • 2.5L
  • 4 CYL
  • 225,500 MILES
I have looked all over the engine to find the relay location. I located two different fuse boxes under the hood and none of them are where the fuel pump relay is. Even looked under steering wheel found some fuses there but no relay. Please help I have no idea where it could be. And yes I looked through YouTube and Google images already and no help.
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
The fuel pump relay is located in the Intelligent Power Distribution Module Engine Room (IPDMER). Attached is a picture. I circled it in red below.
Here is a guide to help you test the relay as well
DAVEMANLEY
  • 2.5L
  • 4 CYL
  • 115,000 MILES
Replace the fuel pump in the car still won’t start after hearing feel pump humming. Car just previously running.
  • 52,797 POSTS
Good afternoon,
Can you hear the pump after replacing the relay?
There should be 2 powers to the relay with the key on. One is fused control and one is powered by the ECM relay.
Can you feel the relay energize when you turn on the key?
JHRNDZ
  • 2.5L
  • 4 CYL
  • 15,789 MILES
My car had stopped working. I charged the battery got it going for three days, it stopped working again. I tried to charge the battery, but it would not hold a charge. I purchased a new batery and it still had a hard time starting the car. I gave it a good kick of gas and it turned on. Tested the starter and alternator no problem there, service light went off. The car did good for a week and now will not start again. I look online and was given several possibilities of what it could be, spark plugs, fuel pump, or head gasket. Here is what happens wen I try to start car; It sounds like it wants to kick over all lights and stereo work fine, the battery is only a week old. After about the third try of starting car it smells like gas, I could be flooding it. A friend said it could be valve cover leaking oil to spark plugs, but really I feel like we are playing a guessing game as to what is wrong with it and I have no idea what to fix. The service light never turned back on so I have no way of checking it. Can you please help me figure this out? Thank you.
KEN L
  • 43,351 POSTS
Hey JHRNDZ,
It sounds like the ignition relay has gone out and not giving the ignition coil a signal that why you smell the fuel from the injectors, here is a diagram on its location, test or replace it and get back to us please.
Here is a link for the testing
Best Ken
MKOROMA06
  • 2005 NISSAN ALTIMA
  • V6
  • 150 MILES
Changed the fuel pump recently, but now I have to change the fuel pump relay. I bought a Duralast relay and I do not know where the location of the fuel pump relay is to put it in. The car is the SE-R model.
KEN L
  • 43,351 POSTS
I found the relay location for you along with the guide to help you test it to see if it is the problem. Relay diagram (below).
KEVIN'S NISSAN
  • 144,210 MILES
I bought a new fuel pump relay but can't find where it is located. Can you please send a picture of where it is located at? I bought the book but it's not helping. My car will crank over, but it's not wanting to fire. It will just crank over and crank over. What do you think it might be?
  • 52,797 POSTS
Good morning,
The relay is in the under hood fuse block. I attached the location for you.
Can you hear the pump run when you turn the key on? It should run for 2 seconds and shut off.
Did you check for spark? Crank the engine and see if the tachometer moves up a little while cranking. That will tell me if the crank sensor is working.
23JPC09
  • 3.5L
  • 6 CYL
  • MANUAL
  • 150,000 MILES
Where is the fuel pump relay located in the car listed above?
BMDOUBLE
  • 1,139 POSTS
Here is the location of the relay in the diagrams below with a guide to help you check it
MARTIN0514
  • 2003 NISSAN ALTIMA
I got a 2003 Nissan altima with a 3.5 engine, it has 125k on it. The car will turn over but won't start, I notice that there's no fuel going to the fuel rail, (I disconnect the fuel line going to the fuel rail) The 10 amp fuse in the engine compartment next to the coolant recovery is not blown, I look for a fuel pump relay but I couldn't find one the question for you the experts where do I go next to find the problem. Thanks OKC man
Hi Martin0514, Welcome to 2carpros
The FP Relay is in the intelligent power distribution module in the right front engine compartment. Check fuse no.32 15amp in the IPDM Do this find the fuel pump connector and power the black and yellow wire from the battery this will cause the fuel pump to come on.
https://www.2carpros.com/forum/automotive_pictures/12900_IPDM_1.jpg
