Pinout diagram needed?
SCION
  • 2005 SCION XB
  • 1.5L
  • 4 CYL
  • MANUAL
  • 60,506 MILES
I need a pinout diagram + wire diagram for the vehicle listed above, for the wire diagram. I need it to be something like which color does what, and for the pinout I need it to be like which pin does what. Thanks.
Thursday, June 29th, 2023 AT 3:57 PM
  • 108,489 POSTS
I would be happy to help, but I need to know what circuit you need it for. Otherwise, there will be pages of pics below and wiring schematics.
For example, do you need the powertrain management schematic and a pinout of the PCM?
If you are not sure, let me know what you are working on and what the vehicle is doing.
Thursday, June 29th, 2023 AT 11:15 PM
SCION
  • 28 POSTS
Thank you for your response, but there must be a misunderstanding here, so you see I included all my details (Vehicle, Question) on the title, and I see the title is not showing. So, I'm going to include all my details in this reply, because my question did not include in the title.
Vehicle: 2005 Scion xB
Question: How to test a cluster (odometer, speedometer) for a 05 Scion xB.
What I need: Pinout diagram, wire color diagram.
Thank you :)
*P.S - I added a images to show you what a 05 Scion xB cluster looks like
Friday, June 30th, 2023 AT 9:40 AM
  • 108,489 POSTS
That makes it easier. LOL I'm not sure why it didn't attach.
Regardless, I attached the wiring schematic for the cluster below. The connector pin identification is included in the schematic.
Note: I had to cut the pic in half to make it readable for you. However, I did overlap the two so you can follow from one to the next.
Let me know if this is what you needed.
joe
Friday, June 30th, 2023 AT 9:26 PM
SCION
  • 28 POSTS
Thank you so much for the diagram, Joe, but are you able to tell me which one is the power? Thank you so much.
Saturday, July 1st, 2023 AT 10:34 AM
  • 108,489 POSTS
You are very welcome. As far as the power supply is concerned, it appears to be the black wire with a red tracer (pin 40). It provides power with the key in the start and run positions. Also, there are a couple of others as well. (Pins 1, 23, and 40)
I attached a pic below and highlighted what I am seeing as the power supplies. Let me know if that helps.
See pic below.
Saturday, July 1st, 2023 AT 7:23 PM
SCION
  • 28 POSTS
OMG. Thank you so much, you are so helpful, Joe, you have saved me lots of frustration. I feel dumb, lol. Can you please tell me which one is the negative terminals? Thank you!
Saturday, July 1st, 2023 AT 8:21 PM
  • 108,489 POSTS
Don't feel dumb. We are all the same. We require being told how. You are no different than anyone else.
Looking at the schematic, it appears pin 21 (brown wire) is ground. See pic below.
Let me know if this helps or if you have questions.
See pic below.
Saturday, July 1st, 2023 AT 10:20 PM
SCION
  • 28 POSTS
The kindness is too much, Joe! Thank you so much for helping me! I may come back to this and asked a few more questions in the future, if that's okay. Thank you, Thank you, Thank you!
Sunday, July 2nd, 2023 AT 8:58 AM
  • 108,489 POSTS
You are very welcome. And certainly, you are always welcome to return.
Take care of yourself and I hope you have a great 4th of July.
Sunday, July 2nd, 2023 AT 1:43 PM
SCION
  • 28 POSTS
Thank you, Joe. What does the red X mean on pin 36? (Color black)
Happy 4th of July and take care.
Sunday, July 2nd, 2023 AT 1:50 PM
  • 108,489 POSTS
I put the X there because I didn't want you to think that it was a power or ground supply.
Sunday, July 2nd, 2023 AT 2:30 PM
SCION
  • 28 POSTS
Thank you for that, Joe. But I think I am doing something wrong, I am trying to test this cluster, but not the usual way. Here is what I'm using:
Cluster
Cluster wire harness (OEM)
Phone power bank (5V, 8.4, 12V, 16, 20V [you can switch the voltage], 50,000mAH)
USB cable
Jumper cables (small)
Though, on amazon I ordered pinout cables (male to female, I will cut off the female end), they should be here tomorrow to my location, though, I am unsure if I did something wrong. I will be waiting until the cables I ordered are here. In the meantime, can you please tell me what could be wrong? (Wrong voltage, wrong mAH, etc) Thank you, Happy 4th of July.
Sunday, July 2nd, 2023 AT 4:42 PM
SCION
  • 28 POSTS
Hey Joe! Great news! I got it working! Thank you so much! The cluster has 213K Miles, it's amazing! Thank you, thank you, thank you!
Monday, July 3rd, 2023 AT 3:21 PM
  • 108,489 POSTS
Thanks for the update. I'm glad to hear you got it working. That's a lot of miles. LOL
Take care and feel free to come back anytime in the future.
Happy 4th!
Monday, July 3rd, 2023 AT 10:11 PM
SCION
  • 28 POSTS
Hi Joe! Question, do you know which pins are the speedometer, the gas and RPM gauge pins? Thank you and Happy July!
Tuesday, July 4th, 2023 AT 5:36 PM
  • 108,489 POSTS
I just saw this. I lost power last night at home so sorry for the delay. I looked at the schematic and it isn't indicated. By any chance, have you been able to make progress?
Thursday, July 6th, 2023 AT 8:08 PM
SCION
  • 28 POSTS
Hi, I'm sorry that happened. But, yes, I have made progress, I have found that all the indicators are powered but will turn on if you put it on a negative output. Also, what are these things on the outside of the diagram? It shows the "Speedometer" and other things. Could you help me out with that? Thank you
Friday, July 7th, 2023 AT 3:14 PM
  • 108,489 POSTS
Those are the circuits within the cluster. Note that the speedo is hooked into a CPU. That is why I'm struggling to find the pin number for you. What you are seeing is what two manuals provide.
Friday, July 7th, 2023 AT 7:33 PM
SCION
  • 28 POSTS
Hi Joe, I found out that the Speedometer is not integrated into the motherboard, its actually wired from the mother board (not the primary one) to the gauges. I will send a picture here to show you what I mean. It goes from 1 - 16, is there any information on that? Thank you
Sunday, July 9th, 2023 AT 10:11 AM
  • 108,489 POSTS
They don't show that. I suspect because it is wired via a CPU. Is that what you are referring to?
Sunday, July 9th, 2023 AT 6:53 PM
Related General Content
