Air conditioner and heater only working on one side?
YMI2GR84U
  • 2002 BUICK LESABRE
  • 3.8L
  • 300,000 MILES
I am not getting cold air on drivers side only the passenger side. The drivers side is straight hot. I am not sure which actuator is bad. Where is the location of the drivers side temperature actuator and the air blend actuator? Please show a diagram of my HVAC dual system and which actuator is more likely the problem. Oh and the system is automatic.
Thursday, February 28th, 2019 AT 9:48 PM
  • 52,797 POSTS
Good morning,
This happens when the right or left temperature blend door actuator goes out. This guide can show you how a typical system works and where the actuators are located. I have included diagrams for your car below.
Yes, it is an easy replacement. It is under the dash, left side.
I attached a picture and the procedure for you to view.
1. Remove the left side sound insulator.
2. Remove the knee bolster.
3. Remove the Instrument Panel Module (IPM).
4. Disconnect the electrical connector from the air temperature actuator.
5. Remove the air temperature actuator retaining screws (1).
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Friday, March 1st, 2019 AT 3:56 AM
MIDWESTERN333
  • 3.8L
  • 6 CYL
  • 145,000 MILES
When temperature on heat driver's side able to get hot air from floor, mid, or def, but passenger side blows cold.
Ran scan tool and got code B0279.
Monday, March 22nd, 2021 AT 2:14 PM (Merged)
  • 52,797 POSTS
Good afternoon,
The code s for the actuator. I attached the description below as well as the instructions for replacing the actuator.
It is behind the glove box.
REMOVAL PROCEDURE
1. Remove the IP compartment.
2. Disconnect the electrical connector from the air temperature actuator.
3. Remove the air temperature actuator retaining screws (1).
ImageOpen In New TabZoom/Print
4. Remove the air temperature actuator.
279
CIRCUIT DESCRIPTION
The instrument panel integration module (IPM) commands right air temperature actuator movement with one of three voltage signals applied to the right at temperature door control circuit. A low voltage of 0 volts moves the right air temperature door toward full hot. A voltage of 2.5 volts stops the actuator. A voltage of 5 volts moves the right air temperature door toward full cold. The IPM determines the current position of the actuator by monitoring the feedback voltage of the right air temperature door position signal circuit. The feedback potentiometer position is a function of the actuator position. A high voltage indicates a full cold right air temperature door position. A low voltage indicates a full hot right air temperature door position. The IPM controls the right air temperature door position in order to maintain the selected air temperature on the HVAC control module.
Whenever the IPMs keep alive memory battery power is interrupted, the IPM will perform a recalibration of the actuators. During recalibration, the IPM will drive the actuators to their minimum and maximum travel extremes. The IPM will then calculate a travel range from this data, max-min=range, and compare it to a calibrated range within the IPM. If the actual travel range is not within the calibrated expected range, the actuator will be considered not calibrated and the DTC will set.
CONDITIONS FOR RUNNING THE DTC
The ignition is turned ON.
The IPM power must be interrupted.
Perform the Recalibrate all Motors command using the scan tool.
CONDITIONS FOR SETTING THE DTC
The right air temperature actuator actual total travel range (max-min) is less than or greater than the calibrated limits.
ACTION TAKEN WHEN THE DTC SETS
The IPM will continue to make use of whatever right air temperature actuator travel range is still available.
Each time the ignition switch is turned ON, the instrument panel integration module (IPM) will perform a recalibration of the actuator.
CONDITIONS FOR CLEARING THE DTC
The right air temperature actuator travel range error must be corrected.
The history DTC will clear after 50 fault free ignition cycles.
DIAGNOSTIC AIDS
If the condition is not present, refer to Testing for Intermittent and Poor Connections in Diagnostic Aids.
The range fault code can only be detected following a test of the right air temperature actuator travel range: This test can only be initiated by disrupting power to the IPM, that is, by disconnecting the battery or with the scan tool.
The calibration limit is 147-220 counts (2.9-4.4 V). An actual range below this limit suggests an obstruction, something Stuck in the door' limiting travel. An actual range above this limit suggests an over travel condition, damaged or missing foam seals.
SUTTONJEFF
  • 330,000 MILES
Why does heat only come from the left side of the cab and cold air from the ride side of my 2002 Buick Lesabre? When I use my air conditioning in the summer I get warm air from the drivers side and cold air from the passengers side. In the winter I get the same with only the drivers side giving me warm air. Can you diagnose the problem?
Thank you,
Jeff
Monday, March 22nd, 2021 AT 2:15 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
Probably a bad blend door actuator on the cold side, assuming you have separate controls.. This guide can help
let us know
JEFF SCOTT WOOLEY
  • 2001 BUICK LESABRE
  • 3.8L
  • 6 CYL
  • 136,500 MILES
Heat blows fine on passenger side but cold on driver's side. I have located the blend door actuator behind the glove box, but I don't know if there is another one for the driver's side. It is the car listed above Limited model with digital temperature control.
  • 108,489 POSTS
You will have a separate one for the left side (driver's side). See picture 1
Now, there are two different systems, automatic temp control and manual. I will provide the directions for both. I will start with the automatic system. The attached pics correlate with the directions.
____________
2001 Buick LeSabre V6-3.8L VIN K
Air Temperature Actuator Replacement - Left
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures HVAC System - Automatic Air Temperature Actuator Replacement - Left
AIR TEMPERATURE ACTUATOR REPLACEMENT - LEFT
REMOVAL PROCEDURE
pic 2
1. Remove the left side sound insulator. Refer to Closeout/Insulator Panel Replacement - Left in Instrument Panel, Gauges and Warning Indicators.
Pic 3
6. Remove the air temperature actuator.
INSTALLATION PROCEDURE
pic 4
1. Install the air temperature actuator.
NOTE: Refer to Fastener Notice in Service Precautions.
Pic 5
2. Install the driver air mix retaining screws (1).
Tighten
Tighten the fasteners to 1.4 N.M (12 lb in).
3. Connect the electrical connector to the air temperature actuator.
4. Install the IPM.
5. Install the knee bolster.
6. Install the left side sound insulator. Refer to Closeout/Insulator Panel Replacement - Left in Instrument Panel, Gauges and Warning Indicators.
7. Recalibrate the actuator. Refer to Re-Calibrating Actuators.
__________________________________
If you have manual temp control, it should only have one actuator. Here are the directions for that.
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures HVAC System - Manual Air Temperature Actuator Replacement
REMOVAL PROCEDURE
pic 6
1. Remove the IP compartment. Refer to Storage Compartment Replacement - IP in instrument Panel, Gauges and Warning Indicators.
Pic 7
pic 8
Pic 9
2. Install the air temperature retaining screws (1).
Tighten
4. Install the IP compartment. Refer to Storage Compartment Replacement - IP in Instrument Panel, Gauges and Warning Indicators.
5. Recalibrate the actuator. Refer to Re-Calibrating Actuators.
RE-Calibrating Actuators - HVAC System - Manual
Vehicle Heating and Air Conditioning Testing and Inspection Programming and Relearning RE-Calibrating Actuators - HVAC System - Manual
RE-CALIBRATING ACTUATORS - HVAC SYSTEM - MANUAL
CALIBRATION PROCEDURE
Use the following steps to perform the calibration update.
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
IMPORTANT: The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
____________________________________
Let me know if this helps.
JOE DIEDRICH
  • 3.8L
  • 6 CYL
Heater blows warm air on drivers side but wont on passenger side
This is due to the blend door actuator on that side is not functioning. Here is a guide that will help with this:
Also, below is the process from the manual on how to replace this actuator. Let us know if you have other questions. Thanks
OHIOSTEVE45344
  • 2000 BUICK LESABRE
  • 3.8L
  • 6 CYL
  • FWD
  • 175,000 MILES
My ac works great on both driver and passanger side. When I change the temp to 90 and hit the deforst I get cold air driver side and hot air passanger side. I have replaced the driver side blend door acuator 2 times and still I cant get the system to work correctly. When I removed the firs blend door acuator the actuator didnt move at all. I took it back and got another one and all it did eas moved about 1/16 of an inch each way. I recieved warm then cold air back and forth. If I remove the blend door acutator on the driver side I can turn it manually and get hot air, or cold air depending on what position I put the actuator door in. I do have digital readings on the HVAC unit and the car has dual climate control. I have went to the junk yard and replaced the AC head with several different haeds and still no change. I also have no lights on the buttons on the HVAC control system.
HMAC300
  • 48,600 POSTS
There are five fuses that run the system lets check them all for power and if okay you must have a shorted wiring causing the issue here are two guides to help us get started with the HVAC wiring and fuse diagrams below. The diagram show which fuses to test.
and
BOOPERIII
I had the same problem and had a pin that was pulled at the actuator.
JEFF SCOTT WOOLEY
I have a 2001 Buick LeSabre Limited and the driver's side blows cold when the heater is on. I found the passenger side actuator module and it moves but I don't know where the driver's side actuator (if it has one) is located. Please help.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
It looks like the blend door actuator for the drivers side is near the drivers side foot well. Check out the diagrams (below). Please let us know what happens.
KEITHMCF
  • 1998 BUICK LESABRE
  • 6 CYL
  • FWD
  • 46,000 MILES
My lesabre air conditioner has worked flawlessly for years and now all of a sudden works only intermitently. Stranger still hot air blow out vents on passenger side but cool air on driver's side. AC recently checked and only change has been new serpentine belt. What is the cause and what is to do about it?
MADMIKE1735
  • 951 POSTS
Sounds like a blend-air door issue. When you change which vents you want air to blow out off, do you hear any noise from under the center of the dash? If not your blend air door is stuck, or the cable has somehow become unattached.
SANDYSLUPE
  • 1997 BUICK LESABRE
  • 6 CYL
  • 132,000 MILES
Heat is blowing out of passenger side but cold air out of drivers side.
Monday, March 22nd, 2021 AT 2:16 PM (Merged)
KEN L
  • 43,468 POSTS
This sounds like you have a blend door actuator that is not working. Here is a guide to show you what you are in for when doing the job and the location of the actuator is in the diagrams below:
Cheers, Ken
  • 52,797 POSTS
Even though it is manual control, do you have dual controls? Control for each side?
I do not see dual actuators which may mean you have another issue.
SANDYSLUPE
No. One control.
