After replacing the turn signal switch on the steering column, the vehicle will not start, pass lock?
SASSYBELL45
  • 2002 CHEVROLET TAHOE
  • 100,000 MILES
My boyfriend replaced the turn signal switch on steering column. Now it won't start.
Wednesday, March 27th, 2024 AT 7:38 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
Can I ask if the security light is flashing when you try to crank the engine over? If not, then the pass lock has not been activated. If so, you can try a hard system reboot which will clear the systems and allow them to reboot.
Here are two guides that can help:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
and
https://www.2carpros.com/articles/how-to-reset-a-security-system
Also, I would make sure the ignition switch is still plugged in, which can sometimes come undone when doing the turn signal switch. Check out the images (below). Please let us know what happens.
Wednesday, March 27th, 2024 AT 10:05 AM
KEN L
  • 43,351 POSTS
Anything?
Saturday, May 11th, 2024 AT 12:58 PM
