Starter replacement instructions needed
SPARKEV
  • 2014 HONDA CIVIC
  • 1.8L
  • 4 CYL
  • 60,000 MILES
I'm looking for detailed instruction on how to replace the starter. I've replaced starters on older cars and if it's not too complicated. I'll be replacing one on this car listed above.
Thursday, September 10th, 2020 AT 3:24 PM
As requested. Here are the instructions from the manual. Let us know if you need more info. Thanks
Thursday, September 10th, 2020 AT 4:09 PM
SPARKEV
  • 10 POSTS
Thank you!
Thursday, September 10th, 2020 AT 4:29 PM
You are welcome. Please come back to 2CarPros in the future if you have other questions. Thanks
Thursday, September 10th, 2020 AT 7:25 PM
ALFRED HILL
  • 7 POSTS
  • 2009 HONDA CIVIC
  • 1.2L
  • 4 CYL
  • FWD
  • 111,000 MILES
I cannot get to my starter to check things.
Friday, January 22nd, 2021 AT 1:22 PM (Merged)
HMAC300
  • 48,600 POSTS
If it is not starting and you have a known good battery try resetting security system. See the link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
if starter is bad see pictures for removal.
ALFRED HILL
  • 7 POSTS
I want to know what I have to take apart to get to the starter as it is buried on back side of engine. Everything is in the way.
CJ MEDEVAC
  • 11,004 POSTS
Did you click on the pictures that HMAC300 provided above?
The Medic
ALFRED HILL
  • 7 POSTS
The picture just shows how starter comes out. I need to know-how to get to the starter, as the manifold is hiding it. The pictures do not show that.
HMAC300
  • 48,600 POSTS
If you would read the instructions on the picture it tells you everything to remove starter.
ALFRED HILL
  • 7 POSTS
Yes it tells how to remove starter, but what do you have to take off to get to the starter? The manifold is blocking it at the top.
HMAC300
  • 48,600 POSTS
If you follow the steps you should be able to do this. This was taken form a 1.3L Honda as it does not show a 1.2L. Try from bottom if this is not sufficient I apologize as this is all we have.
Friday, January 22nd, 2021 AT 1:23 PM (Merged)
CALLIE02
  • 2007 HONDA CIVIC
  • 1.8L
  • 4 CYL
  • 124,000 MILES
Trying to remove and replace starter. Does anyone have a step by step picture of how to do this?
Thank you,
Brenda
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here are the instructions on how to remove this starter: Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Here is the location in the diagrams below. Please let us know if you need anything else to fix it.
TORA_SEGEUL
  • 2007 HONDA CIVIC
  • 2.4L
  • 4 CYL
  • MANUAL
  • 12,000 MILES
Where is the starter located and how do you change it?
ED-WEEZY21
  • 248 POSTS
Here is a guide that will show you how to change it out with a diagram below to show you the starter location.
MATTHEW FOX
  • 2007 HONDA CIVIC
  • 2.0L
  • 4 CYL
  • MANUAL
  • 81,000 MILES
I have a new starter and I am ready to install it. Is it easier to go from under the car or take the intake manifold off and just work up top?
HMAC300
  • 48,600 POSTS
See pictures for removal and reverse for install. Make sure to remove knock sensor for easier access and not to break it. Also remove negative battery cable prior to beginning.
ALFRED HILL
  • 7 POSTS
Not enough info. What do you take off after taking manifold brkt off? Does the manifold come off?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Hi ALFRED,
No the manifold stays on, you only take off the manifold to gain access to the starter.
Let me know if you have any other questions.
Best, Ken
SCOTTYMC
  • 2007 HONDA CIVIC
  • 4 CYL
  • 98,000 MILES
How to remove starter from 1.8 2007 honda civic ex
