Fuse diagram not one in the user manual?
LCOLLINWARD
  • 2017 VOLKSWAGEN JETTA
  • 1.8L
  • 4 CYL
  • MANUAL
  • 45,000 MILES
There is not one in the user manual or on the back of the fuse box cover.
Friday, February 8th, 2019 AT 12:02 PM
  • 108,375 POSTS
Here are the fuse allocations. I had to attach the list in several pictures. Let me know if this helps or if you have other questions. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Friday, February 8th, 2019 AT 8:38 PM
LCOLLINWARD
This is awesome. Thank you. Do you know if this applies to all models?
Saturday, February 9th, 2019 AT 12:38 PM
LCOLLINWARD
To clarify, does this apply to all sub-models of the 2017 Jetta?
Saturday, February 9th, 2019 AT 12:52 PM
  • 108,375 POSTS
Hi and welcome back:
That is the only one they show, so I assume yes. There may be things listed on it which your vehicle doesn't have.
Let me know if you need anything.
Saturday, February 9th, 2019 AT 8:06 PM
MAVERICK02
  • 2012 VOLKSWAGEN JETTA
  • 21,000 MILES
When I use the wipers on intermittent, there is a clicking coming from the fuse box when the wipers start. Click when the wipers start and click when the wipers stop. This of course is happening every 10-15 seconds because of the low settings. I understand the current starts and stops with ever movement, however I don't want to hear a click from the fuse box. What do I need to do, check the fuses?
Tuesday, July 14th, 2020 AT 12:10 PM (Merged)
EXOVCDS
  • 1,883 POSTS
Here is a guide to help check the fuses and the fuse location in the diagrams below.
Check out the diagrams (Below). Please let us know what you find.
M.GUTIERREZ
  • 7 POSTS
  • 2010 VOLKSWAGEN JETTA
  • 5 CYL
  • TURBO
  • 150,000 MILES
I need a fuse diagram for both internal and external fuse boxes. The in desperate need!
94 TRANSAM
  • 680 POSTS
Hi, welcome to 2CarPros.
I need the 8th digit in your VIN so I can look up your vehicle.
Thank you, Rich
M.GUTIERREZ
  • 7 POSTS
Hello the 8th character in my VIN is: J, however is not a digit. Is this what you mean? The full VIN is 3VWRZ7AJ2AM053761
94 TRANSAM
  • 680 POSTS
You will find the info below. Let me know if you need anything else.
Rich
M.GUTIERREZ
  • 7 POSTS
Thank you for the response! I see that the list that has SC1, SC2, SC3 and so on are for the internal fuses. However for the outside one, Fuse E-Box, I don't understand. I see it's component, but I don't know where to put it and what volt level the fuse should be, thanks!
94 TRANSAM
  • 680 POSTS
Sorry, these are the diagrams for the one under the hood and the one under the dash.
All voltages in all fuse blocks are 12 volts. Some voltages out of the computer are 5 volts.
Rich
M.GUTIERREZ
  • 7 POSTS
Hello Rich,
Unfortunately I'm still confused. If you refer back to the very first image you sent me on the first bundle of files (under the hood fuse diagram ), you'll see that it goes from sb1 all the way to sb50 (fuses) however the recent list you sent me only goes up to sb18. Is there still more to the list? I also don't understand what fuse panel A is for? Thanks
94 TRANSAM
  • 680 POSTS
Okay, sorry again. This tiny car has more fuses than 6 American cars combined! I am also having to use 2 different sources to get this info which is making it difficult.
I am seeing this car has 4 fuse/relay boxes. Is that correct? Do you want the info for all 4?
I will keep digging tonight but at this point I think I pieced together all the info for the under hood main box. Posted below. Let me know if this is not right. And as I said I will dig for the others.
Rich
94 TRANSAM
  • 680 POSTS
Okay, this should be the main box inside the car. Do you need the 2 relay centers also?
Rich
M.GUTIERREZ
  • 7 POSTS
Hello Rich, the under the hood fuse box does not match. Can you refer to another one please? I have one with 2 100 blocks.
M.GUTIERREZ
  • 7 POSTS
You also gave me to two different lists of the inside fuse panel, the second list does not match the first one.
94 TRANSAM
  • 680 POSTS
Okay, I have the 8th VIN#, I have the year etc. That info is based on one model Jetta. There are 3 different Jetta's. It was my assumption they all had the same wiring. So what model Jetta do you have? And is it 2 door, 4 door, hatch back, auto or standard transmission?
This is nuts! Hahaha.
Rich
M.GUTIERREZ
  • 7 POSTS
Mine is the Jetta Sedan.
94 TRANSAM
  • 680 POSTS
Okay, this is what I have for your vehicle. If this is not right let me know and I will pass this to someone else and see if they can find something I can't. The diagrams are named what the fuse panels are called.
Rich
