Fuse diagram not one in the user manual?
MILO2001
  • 2007 VOLKSWAGEN JETTA
  • 1.6L
  • 4 CYL
  • MANUAL
  • 26,000 MILES
Fuses put back in wrong place now car is showing Brake light symbol skidding symbol and others, all he has done is took fuse out one by one to check but because of spaces got confused
Tuesday, July 14th, 2020 AT 12:12 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
I found these diagrams for you it shows the fuse amp rating and the number slot they go into and a guide to help you test them
IVAN AZCUE
  • 25 POSTS
  • 2005 VOLKSWAGEN JETTA
  • 2.5L
  • 5 CYL
  • 220,000 MILES
I'm looking for fuse panel information/diagrams of the inner panel and the engine compartment
engine code BGQ.
I've heard there are different variations my production date is November 2004.
STEVE W.
  • 13,150 POSTS
Welcome back. These are the fuses, locations and the circuits powered by the fuses for the underhood and interior boxes. For the Jetta build date Nov. 2004
What is the the issue you are having?
ANN BLUE HARRIS
  • 5 POSTS
  • 0.5L
  • 6 CYL
  • 4WD
  • 18,000 MILES
I need the fuse diagram to know what fuse is for what. My car doesn't have the paper for the interior or exterior.
  • 108,489 POSTS
There is no V6 shown for this vehicle, so I will attach the information for both the 1.8T and the 2.0.
The first pictures are for the 1.8T. Pictures 1 and 2 are of the interior fuse panel (left side). Picture 3 is the battery bracket. Picture 4 fuses on relay panel
2.0L
Picture 5 and 6 left side fuse panel. Picture 7 is the battery bracket. Picture 8 is the fuses on the relay panel.
  • 108,489 POSTS
2.0L
ANN BLUE HARRIS
  • 5 POSTS
It didn't give me the option for a 5 cylinder my car is 2005 Volkswagen Jetta 2.5L it doesn't have the fuse guide that says what fuse goes to what interior or exterior.
  • 108,489 POSTS
Pic 1 Fuses under hood on electronics box
Pic 2, 3, 4 Interior fuse panel legend and layout
Let me know if this helps.
ANN BLUE HARRIS
  • 5 POSTS
Thanks for this information. The pictures sent were internal fuses 1-4 and 14-36 I have 49 fuse slots in my car. This is the right diagram and guide I just need 1-49 internal and all fuses for external under the hood. Thanks again
ANN BLUE HARRIS
  • 5 POSTS
My cars internal fuse box I need 1-49 fuse numbers and what they all control.
  • 108,489 POSTS
That's fuse panel C. See the attached pictures.
There may be fuses listed that are not used.
DANNY CAVENDISH
  • 2002 VOLKSWAGEN JETTA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 216,344 MILES
Somebody had tried rewiring the fuse box. I would like to get a color code and numbered location for each wire. It's a standard model with no extra features can somebody please help, I can't really afford to pay the dealership $120.00 per hour to have this job done when I am perfectly capable.
Tuesday, July 14th, 2020 AT 12:13 PM (Merged)
  • 108,489 POSTS
Here is the problem: There are several fuse boxes on this vehicle. What I am going to try to do to help is this. First, I am going to provide the entire power distribution wiring schematic which indicates what fuse box is supplying power and wire color and fuse number. Then I will provide what each fuse is for. Please understand, there are many pages of the schematic. I have to, at a minimum, cut them in half to make them readable for you. I will keep them in order and overlap them so you can follow them easier.
Pics 7 and 8 Instrument panel left.
I hope this helps.
JOYPARADISE
  • 2000 VOLKSWAGEN JETTA
Interior problem 4 cyl Two Wheel Drive Manual 92000 miles
I bought my daughter a 2000 Jetta this weekend and the cigarette lighter doesn't work for her to plug in a GPS. It looks as if something was spilled in it. Where can I find a diagram where I can check the fuse?
KEN L
  • 43,468 POSTS
Here is a guide to help you test the fuse #41 located it from these diagrams of the fuse panel (below):
Open the driver door and look at the side of the dash, you will see an access panel, pop it open and you will see the fuses. The cover will have a small card attached to it with icons. Look
for a cigarette icon to match-up which fuse to check. Here is the fuse panel identification
Check out the diagrams (below)
Cheers, Ken
RYAN BROWN
  • 6 POSTS
Hey Experts! The first diagram posted here at the top is the one for my vehicle! 2017 Jetta GLI. The only issue I’m having is trying to pinpoint which fuse corresponds with the rear running tail lights (drivers side). The fuses in that diagram aren’t always labeled what I would look for, (for instance windshield wipers is F10 - Right Steering Column Switch), so I’m wondering if there is a more technical term I’m just overlooking that corresponds with the drivers side tail light that I’m missing?
Wednesday, April 28th, 2021 AT 1:24 PM
  • 108,489 POSTS
If you look below, I attached a small portion of the wiring schematic from above. I highlighted the wire to the tail light (left side). Power is provided from the electrical control module, behind fuse panel C. Thus, there isn't a specific fuse. What you would have to do is check that pin for power.
Have you checked the grey/black wire at the tail lamp for power? If you haven't do that. Here is a link that you may find helpful:
Let's first confirm that it isn't an issue with the light socket or a bulb.
Let me know what you find.
Wednesday, April 28th, 2021 AT 5:26 PM
RYAN BROWN
  • 6 POSTS
Hey Joe! Appreciate the help!
Here’s what we know so far:
It’s not the bulb (replaced them with fresh ones), no dice. Swapped the left and right units - and the unit that wasn’t working works on the passenger side, and the unit that was working does not work on the drivers side.
Additionally - the running tail light does come on for certain things. When it’s in park (this is a new development as of today) and when the brake is applied (but there is about a 3 second delay - whereas the brake lights come on immediately).
So I know the thing can work, so guessing it’s not the wiring. Wasn’t sure if there is a separate fuse for the brakes vs running tail light to explain why it works for certain functions.
Wednesday, April 28th, 2021 AT 8:33 PM
RYAN BROWN
  • 6 POSTS
Also just want to thank all the experts on here for taking time out of your day to come help random strangers. You guys rock!
Wednesday, April 28th, 2021 AT 8:36 PM
