Rack and pinion removal
  • 108,489 POSTS
I would think you would be fine if you can just straighten it. It looks like it is just a rubber boot that the shaft goes through.
Tuesday, April 7th, 2020 AT 7:41 PM
JORDAN013
  • 55 POSTS
You are correct, it is a rubber boot for shaft to go through. I have gotten the driver side of the rack dropped as far as it will go for now. I have yet to get the bracket for the exhaust off. But think that will allow the rack to drop straight down for the shaft to clear.
Wednesday, April 8th, 2020 AT 3:22 PM
  • 108,489 POSTS
You are getting there. This isn't a small job. Listen, I don't know what tools you have. If there is any chance you have a 6 point box end wrench, it will help prevent the bolts on the mount from being damaged or stripped.
Let me know how you make out or if you have other questions.
Wednesday, April 8th, 2020 AT 6:37 PM
JORDAN013
  • 55 POSTS
Update: Thank you for all of your help and tips it is greatly appreciated and I couldn't have gotten it removed if it weren't for you. I found the perfect ratchet and socket combination and supported the rack as I removed the bracket and sure enough once the bracket was removed the rack lowered beautifully. Tomorrow I plan to disconnect rubber hanger holding exhaust towards middle of car so that I can drop the exhaust down more. I also want to remove the sway bar to tuck lines back more when installing the new rack, as I plan to change sway bar links anyways. Any tips for installing rack? I plan to use jack on gearbox side to support after sliding rack to right and loosely installing right side bracket, then the two screws that support rack on driver side, followed by connection of shaft to wheel and then I plan to do the lines. Does that sound like best plan of attack?
Wednesday, April 8th, 2020 AT 6:48 PM
  • 108,489 POSTS
First, you are very welcome. It's not an easy job and you are getting there. As far as your plan of attack, absolutely what you said makes sense. When you are doing it, you will see what works and what won't. Feel free to let me know if you have questions or need any help.
Let me know how things turn out for you.
Wednesday, April 8th, 2020 AT 7:15 PM
JORDAN013
  • 55 POSTS
Waiting to install new rack, weather should be better tomorrow. Planning to do the upper control arms before I install new rack and will remove the sway bar since it will help with lines and I have to replace end links anyways. Will provide updates. Thank you :)
Friday, April 10th, 2020 AT 11:17 AM
  • 108,489 POSTS
The wind has been horrible here too. Tuesday night I thought the house would blow over. Actually, a hanger at the local Airport was blown over. Ugh! When you get to it, let me know. If I don't hear from you, I wish you and your family a Happy Easter.
Take care and stay healthy.
Friday, April 10th, 2020 AT 6:26 PM
JORDAN013
  • 55 POSTS
Oh man, that is crazy. Luckily the weather was nice and dry today and I was able to get the new rack in place, hooked up to the steering wheel and got the brackets on (also replaced stabilizer links); planning to install lines tomorrow and outer tie rods. I noticed that one of the lines had some resistance to it, I believe it is an oil cooler line and I may need to bend it a bit with a screw driver very carefully because currently it will go to where it needs to in the rack but I have to angle it weird and feel some resistance when I want to start threading it in which I don’t like. Thank you, I wish you and your family a safe, joyous, and healthy Easter. :)
Saturday, April 11th, 2020 AT 8:07 PM
  • 108,489 POSTS
Jordan,
Make sure when you start threading the line that it goes smoothly. Do it by hand so nothing gets stripped.
Happy Easter to you as well.
Saturday, April 11th, 2020 AT 10:55 PM
JORDAN013
  • 55 POSTS
Everything was going smooth and I was ready to finish installing lines. I installed them smooth but was tightening them to get them all the way seated in. I must have tightened the 17 mm line too much and a piece of the gearbox broke off, luckily I got the broken piece off and that line was fine but then I realized this rack was going to need to come out and I was going to have to install a new one. Again. There was one bolt that was semi stripped so I knew it was gonna be tough to get out but I tried and in the process bent the other line. Both of the 12mm lines will need to be replaced I believe. Lines B and D. Is there a diagram and where can I find new lines? Can I cut them and put new fitting and use those with new rack? I don’t know what to do.
Monday, April 13th, 2020 AT 8:29 PM
JORDAN013
  • 55 POSTS
Broken piece.
Monday, April 13th, 2020 AT 8:31 PM
  • 108,489 POSTS
OMG! That is terrible! I feel really bad for you. However, don't think you are the only one this has happened to. It can happen to anyone.
Listen, I'm not sure what parts you are referring to. The steel lines should be okay. Is that what you are referring to, the steel lines?
Monday, April 13th, 2020 AT 8:43 PM
JORDAN013
  • 55 POSTS
Yes, the one that goes to power steering speed sensor and the one that goes to oil cooler I believe, but I don’t know how I would get them out and where I can purchase them?
Monday, April 13th, 2020 AT 8:52 PM
JORDAN013
  • 55 POSTS
Planning to cut off the damaged parts of the 2 lines tomorrow and get rack removed then I am thinking of either using a compression union to join the line to another section of line same diameter and same end connector for when I install the new rack. Option 2 would be if I have enough length on the pipe, I could get a flare kit to flare the end and put new adapter on it which would allow me to thread into new rack and pinion. What do you think of these options? Would they work? Since these lines go to the cooler and power steering speed sensor, would the unions be able to handle the pressure?
Monday, April 13th, 2020 AT 11:19 PM
  • 108,489 POSTS
Anytime you add a union, there is a chance it will leak. In theory, it should be able to handle the pressure. Well it is another question.
If the pipe is long enough and you can flare it, that is what I would do. Double check if a double flare is needed. I suspect it is due to the amount of pressure it will have.
Let me know if I can help.
Tuesday, April 14th, 2020 AT 9:34 AM
JORDAN013
  • 55 POSTS
Sounds good, I will try to work With the pipe. Do you know where I can find the end connectors that go into the rack And what is the diameter of the connector and that goes into the rack?
Tuesday, April 14th, 2020 AT 9:43 AM
  • 108,489 POSTS
Honestly, I don't know the specifics on it. However, if you remove the old one, a part store or even a hardware store may be able to help.
Tuesday, April 14th, 2020 AT 10:11 AM
JORDAN013
  • 55 POSTS
Thank you, so far I removed the exhaust and bracket and disconnected the other 2 lines that are good. Started to cut bent line but cutter broke so I need to return it and get another one. I think I should have enough meat on the lines to make these work after flaring; need to talk to seller to see if I can get a replacement rack.
Tuesday, April 14th, 2020 AT 11:24 AM
JORDAN013
  • 55 POSTS
Looks like once I get the fitting on the lines I can get them to reach the rack but would I need to bend the area where it curves a bit to get it straighter for the fitting or?
Tuesday, April 14th, 2020 AT 5:18 PM
  • 108,489 POSTS
Yes, don't be afraid to manipulate the steel line. Just make sure if you bend it, it won't hit something that can cause damage or make a noise that will drive you crazy. LOL
Let me know how you make out. Also, the new rack should be replaced because I feel there was an imperfection in the casting or it was damaged when you received it. I never saw that happen before.
Let me know how things are going or if you need anything.
Tuesday, April 14th, 2020 AT 6:03 PM
